Turning angle
Captain_frog
Turning angle
Inlägg av Captain_frog » lör 08 jun 2019 21:18
Hey!
I have read in a Magazin that IF boot has a turning angle of 92°. Wenn I try wiht my IF, my turning angle is far more thant that (110° to 120°).
I sail normaly with a genoa on furling. Could it be that 92° can only be reached with a Jib?
What are your experiences, and what points should I check first to try to improve the turning angle
Any suggestion will be welcome.
Captain Fog
Been liked: 7 times
Re: Turning angle
Inlägg av maja » sön 09 jun 2019 06:25
Do you mean the tack (beat) angle?
If so, this depends on the wether conditions, the sails, the underwater body smoothness and the skills of the helmsman and sail trimmer. Normal is 80 to 100 degrees.
Captain_frog
Re: Turning angle
Inlägg av Captain_frog » sön 09 jun 2019 11:30
Hello Maja!
Yes tack angle is the word I was looking for. Considering that the hull is clean, that I took the motor out of the well, that the sails are 2 seasons old, and that I sail on a lake in Berlin (no waves), I guess that my sailing skill will be the next point to look after.
Nevertheless I had the feeling that the tack angle was better last season, so I thought maybe that a bad rigging of the mast and the fact that I use a Genoa on furling instead of a fock could be an answer to my problem.
Been liked: 4 times
Re: Turning angle
Inlägg av Nils D » mån 10 jun 2019 06:51
If you have changed from sailing with a jib (fock) to a genoa, that probably is the reason for the change of tack angle. I too have a better tack angle when using the jib instead of the genoa. I use the inner sheet tack with the jib which makes it possible to steer closer to the wind. In fact, I noticed this when I reduced my furling genoa to jib size and at the same time changed to the inner sheet tack a year or two ago. So today I only use the genoa in light air and sailing off the wind. I might loose a little bit of speed on some occasions, but since I do not race that is of no great importance.
