diameter cap shrouds
Fer Holland
Inlägg av Fer Holland »
As far as we know, here in Holland some or maybe all IF's were originally delivered with cap shrouds of 6 mm.
In the class rules a size of 5 mm is mentioned for cap shrouds. I suppose this is the minimum, but how long does it last ?
Is 5mm safe enough at the long term ?
Been liked: 8 times
Re: diameter cap shrouds
I suppose you mean the upper shrouds.
5 mm diameter is minimum (which is clearly stated in the class rules), but 6 mm was delivered as original during the -70-ties, as far as I know.
Lately it happens that 5 mm for both upper and lower shrouds is delivered together with a new repalcement rig from Proctor or Seldens. The tension of the upper shrouds is then to be set somewhat higher, i.e. to 15 % instead of 12 %. Also it is wise to check the upper shrouds more often, as the load and consequently the probability for damage is somewat higher.
