Sökningen fann 22 träffar
av iamsville
13 okt 2013 19:41
Kategori: Common
Tråd: IF covers
Svar: 0
Visningar: 6430
IF covers
Hi, I am beginning to update our IF and would like a full cover that I can use while moored in our slip. Are there any manufacturers who already make covers for the IF? I've found one in the UK for the old style Folkboat but not the IT. I'm located in Virginia on the east coast of the US but will ...
av iamsville
14 okt 2012 20:41
Kategori: Segel
Tråd: Main sail
Svar: 1
Visningar: 9185
Main sail
Hi, I'm looking for a new main sail. My IF has an old main from Northsail but I'm not too pleased with the cut. I have it used so it may have stretched and of course it is well worn. However, good quality construction. What supplier do you recommend? Mainly cruising type sailing. thanks. iamsville
av iamsville
07 aug 2011 17:33
Kategori: Skrov
Tråd: Läckande IF-E
Svar: 16
Visningar: 29818
Re: Läckande IF-E
Hi, check the Gudgeons, the bolts that hold your rudder to the keel. I found mine leaking when one had come loose.
iamsville.
av iamsville
23 apr 2011 15:48
Kategori: Common
Tråd: main sail
Svar: 3
Visningar: 12976
Re: main sail
thanks all!
av iamsville
19 apr 2011 02:30
Kategori: Common
Tråd: main sail
Svar: 3
Visningar: 12976
main sail
Hi all, I'm searching for a new or good condition main sail for our Marieholm folkboat. Any recommendations as to where one may be obtained?
thanks,
iamsville
av iamsville
13 okt 2010 01:54
Kategori: Roder
Tråd: Spricka i roder
Svar: 3
Visningar: 10757
Re: Spricka i roder
The outside of the rudder Seams very rough at the water level. Would suggest sometime physical damage to the rudder Perhaps from Being in Water During freeze? Heavy Barnacles? Seems previous damage at area near crack But now Covered by the paint. How long have you owned your IF? As Maia says, note ...
av iamsville
09 okt 2010 14:23
Kategori: Skrov
Tråd: Läckage i akterpiken
Svar: 9
Visningar: 19463
Re: Läckage i akterpiken
Hi, i would recommend checking all the deck fittings in the area. I have had these leak overtime. Good luck!
av iamsville
26 sep 2010 13:58
Kategori: Common
Tråd: Happy New Owner of IF 2595
Svar: 7
Visningar: 20763
Re: Happy New Owner of IF 2595
Thanks Maja, I may try removing my engine and storing it in the locker when under sail. I currently have a 6 hp with the starter cord through the cockpit wall. I have a 4 hp also and wouldn't have to do this to start the engine. It has its own gas tank on the top as well making it all self contained ...
av iamsville
23 sep 2010 02:01
Kategori: Common
Svar: 7
Visningar: 20763
Hi , We've HAD OUR IF for about nine months and Keep It On a lake in Roanoke , VA . We Have a 6hp outboard That we keep in the motor locker. We sometime lose speed on a starboard tack and occasionally pick up water sometime in the locker . This drains though. Port tacks are fine . Maintenance isn't ...
av iamsville
07 aug 2010 15:58
Kategori: Beslag
Tråd: Bomliksträckare och roderfråga
Svar: 7
Visningar: 15586
Re: Bomliksträckare och roderfråga
Believe your tiller is cracked in the round part. Attached Have a picture from my spare. Hope this helps .
av iamsville
03 jul 2010 22:57
Kategori: Skrov
Tråd: Spricka i förstäven
Svar: 7
Visningar: 17318
Re: Spricka i förstäven
I would check the tension or adjustments of your standing rigging. Also, how much tension is on the forestay when you have your IF moored. I do not have this cracking on our IF but always leaving slack in the backstay when moored.
Good luck
av iamsville
10 apr 2010 15:18
Kategori: Skrov
Tråd: läckage
Svar: 11
Visningar: 24523
Re: läckage
Hi,
I had leakage from the bow pulpit and from the lifeline stanchions. Rebedded and haven't had a leak since then.
av iamsville
12 dec 2009 02:42
Kategori: Common
Tråd: Marieholm plaque
Svar: 4
Visningar: 15144
Re: Marieholm plaque
many thanks. Will post a photo when upgrades are completed.
av iamsville
04 nov 2009 23:51
Kategori: Common
Svar: 4
Visningar: 15144
Hi Janne,
Many thanks. The plaque is very thin aluminum and grey. The letters also have no color. I've added a picture and circled the plaque. The letters soon will be black.
Regards
iamsville
av iamsville
02 nov 2009 01:44
Kategori: Common
Svar: 4
Visningar: 15144
Marieholm plaque
My 1976 Marieholm has an aluminum plaque (name plate) on each side of the cockpit. There are no colors but work Marieholm is clear. Does anyone know what the original colors were for this plaque? I would like to return it to original condition.
thanks
iamsville
