Sökningen fann 24 träffar
av skiziks33
11 jan 2012 15:41
Kategori: Common
Tråd: Sheet to Tiller Self Steering
Svar: 6
Visningar: 18382
Success with a sheet to tiller self steering arrangement on your IF or M26? Can anyone describe and show images of the set up that works best for them?
av skiziks33
07 jul 2011 18:10
Kategori: Common
Tråd: Common rudder fracture - left to corrode
Svar: 21
Visningar: 67970
Re: Common rudder fracture - left to corrode
Thanks for all your help and advice folks, in repairing the old and designing the new. The old was filled and faired to it's pre-break form. Then it was used to make a fiberglass mold. The new rudder was laid up using this mold and a sheet of 1/4 inch aluminum alloy was cut to for the inner blade ...
av skiziks33
07 jul 2011 18:01
Kategori: Common
Tråd: headstay backing plate
Svar: 2
Visningar: 11376
Re: headstay backing plate
Hi matt
Did you resolve this problem with your forestay?
Justin
av skiziks33
07 jul 2011 17:12
Kategori: Common
Tråd: Finding new Pintles
Svar: 4
Visningar: 12279
Re: Finding new Pintles
Well I thought I would post the end result after months of delay and shipping errors. I ordered the pintles and 10 new pin bolts from Goran at the Marina in Sweden. He was very helpful, and thank Maja for the contact. Here is a pic of the new rudder completed. rudder.jpg Thanks for all your help and ...
av skiziks33
11 jun 2011 19:16
Kategori: Common
Tråd: Boom topping lift at IF
Svar: 11
Visningar: 23584
Re: Boom topping lift at IF
topping lift.jpg the wire with the block is attached at the top of the mast just 10 cm below the masthead using a 2 screw clip blacket. admittedly, the screws made removing the masthead for antenna wiring more difficult. on end of the lifting line is tired to a clip on the side of the boom using a ...
av skiziks33
23 apr 2011 09:18
Kategori: Common
Tråd: chainplates
Svar: 1
Visningar: 7659
chainplates
While examining the chainplates on my M26, I wondered if the backing plates are the original design or if this was modified by the previous owner. Looking at the attached image, can anyone confirm if this is the original installation? The image quality is poor but what you're looking at is a large ...
av skiziks33
23 apr 2011 09:03
Kategori: Common
Tråd: matching paint
Svar: 8
Visningar: 18560
Re: matching paint
thanks for the responses. i'll update when I can
av skiziks33
21 apr 2011 22:32
Kategori: Common
Svar: 8
Visningar: 18560
matching paint
Hi
Anyone know if there is a paint manufacturer who can color match the original Marieholm colors. My M26 is a greenish blue. Anyone know where I can find this paint? otherwise I will choose a contrasting color for the new rudder being built.
The season is upon us!
av skiziks33
29 mar 2011 18:59
Kategori: Common
Svar: 4
Visningar: 12279
Hi I placed the order for new pintles and pinnbolts with Goran and he has been most helpfull. However, the cost of the new pintles (and shipping to Canada) to replace the old is very high. I don't really want to pay 750 Canadian dollars for this hardware. I will if I must, but.... the reason I ...
av skiziks33
09 mar 2011 18:24
Kategori: Common
Svar: 11
Visningar: 23584
here's an example
av skiziks33
09 mar 2011 18:23
Kategori: Common
Svar: 4
Visningar: 12279
Finding new Pintles
As some of you may recall, I am having a new rudder made of solid glass over an aluminum alloy frame. The mold has been made using the original rudder with pintle cut outs. Where can I find new bronze pintles with the 3 O-rings that will fit exactly into the original gudgeons on the boat? Are the ...
av skiziks33
25 jan 2011 12:12
Kategori: Common
Svar: 21
Visningar: 67970
frankly
for trading weights you've suggesting, I'm hoping for a similar weight to the original
Can the gudgeons and pintles be found somewhere new?
av skiziks33
21 jan 2011 22:20
Kategori: Common
Svar: 21
Visningar: 67970
Hi all. A Rudder update I decided to have a new rudder built using a mold of the old. To order and transport a new Marieholm rudder from Sweden would have been expensive and unnecessarily complicated. The corrosion of the original is too extensive to bother with a repair. Thank you for all your ...
av skiziks33
22 aug 2010 20:58
Kategori: Common
Tråd: M26 vs iF boat - Original Tord S. Hull Drawings and Rig Spec
Svar: 1
Visningar: 7634
Does anyone know if the original Tord Sunden/Marieholm line drawings and spec sheets are available for the M26? The IF boat drawings are available, so perhaps they're to be found on a swedish site somewhere? Are there any notable material construction differences between the if boat and the M26 ...
av skiziks33
22 aug 2010 20:19
Kategori: Common
Svar: 21
Visningar: 67970
After using a epoxy primer on the porous steel, can I create a flat/smooth surface for the cloth using filler first on the steel to fill in an crevices? Or should I cut layers of cloth to build up an even shape of the steel? Can apply wetted cloth directly to the primed steel?
