Sökningen fann 28 träffar
av kubal
10 jun 2015 15:38
Kategori: Common
Tråd: Cable type
Svar: 4
Visningar: 13359
Re: Cable type
When dealing with 0.125 A, do not care about wire cross-section. Mechanical properties are more important. Select the electric cable like a rope: take it into hands and try to judge whether it can withstand the pulling and the wearing by friction with halyards. If it can, than it will have ...
av kubal
13 okt 2014 16:57
Kategori: Common
Tråd: IF boot motor in Winter
Svar: 7
Visningar: 18434
Re: IF boot motor in Winter
One more comment to this. If your engine needs to be replaced by a new one in the future, you should consider using a smaller one which is easier to handle. I have tried 5 HP, 8 HP and 4 HP engines at my IF. I was usually running 5 HP engine at 3/4 of throttle, 8 HP at 1/2 and 4 HP at full throttle ...
av kubal
12 mar 2014 08:32
Kategori: Common
Tråd: Experinces with the Atlantic?
Svar: 2
Visningar: 9846
Re: Experinces with the Atlantic?
Hi Bjorn,
only one technical hint: when sailing in strong wind and big waves in Norway, several brass screws which fix the interior plywood desks to the ribs broke down because of the strong tensions in the hull. I repaired it by screwing stainless steel wood screws near the original brass ones.
David
av kubal
12 maj 2013 20:35
Kategori: Common
Tråd: IF-E New Engine
Svar: 3
Visningar: 14107
Re: IF-E New Engine
Only a small comment to the required power: I think that more than 10 hp is not reasonable. According to my opinion 5 hp is enough. I used 5 hp outboard engine. Later I changed to 8 hp outboard, but I run it at halve the power with the advantage that it is not so noisy. You can look at this engine ...
av kubal
13 feb 2012 18:46
Kategori: Common
Tråd: Water tank for IF
Svar: 3
Visningar: 11816
Re: Water tank for IF
Hello Marek! No, no, this is not the case. I want to stay for periods of one week at some natural anchorages without visiting any harbor. The water installation with pump and sink is already installed in my boat. I only want to replace the flexible tank by a rigid one.
av kubal
13 feb 2012 11:03
Kategori: Common
Svar: 3
Visningar: 11816
Water tank for IF
Dear colleagues, I want to install a triangular rigid plastic water tank under the berth into tho bow cabin. Can anybody recommend a type which fits there? Can, for example, some of Cipax type fit there (www.cipax.com)? I used flexible water tank at this place, but it has shown not to be a good idea ...
av kubal
13 feb 2012 10:56
Kategori: Common
Tråd: Speed and deep transducer problem on Marieholm26
Svar: 4
Visningar: 13146
Re: Speed and deep transducer problem on Marieholm26
I am using in-hull depth transducer at my IF. It works very well. It takes some time to install it, but the advantage of having no additional hole in the hull is significant, I think. You have to find a suitable location for it where the fiberglas is transparent enough for the sound. Do it by ...
av kubal
25 nov 2011 10:07
Kategori: Common
Tråd: IF suitability
Svar: 10
Visningar: 22768
Re: IF suitability
Hi Paul, I have chosen IF boat as my first boat two years ago. According to my sailing experience in the Baltic and partly North Sea this summer, the choice was quite good. To be more specific I am very, very satisfied with the shape of the hull and the behavior of the boat during sailing. On the ...
av kubal
06 sep 2011 17:23
Kategori: Common
Tråd: IF Boat engine location plans
Svar: 7
Visningar: 22551
Re: IF Boat engine location plans
I am having the same problem. Although the outboard engine is quite good at lakes, it has shown to be a total nonsense at raw open sea. What about using some Z-drive with engine either under the cockpit or at the place where the outboard engine is originally located? Does anybody have some idea or ...
av kubal
22 jun 2011 12:19
Kategori: Common
Tråd: Boom topping lift at IF
Svar: 11
Visningar: 23508
Re: Boom topping lift at IF
Yes, you are right. But it is possible to adjust such a length of the topping lift, that it is free when sailing in all conditions. When the main sail is down, the boom is slightly lower than horizontal, so you have to be careful about your head :-). But it is acceptable as a basic setting which ...
av kubal
19 jun 2011 19:55
Kategori: Common
Tråd: Does Honda BF 5 A4 LBU fit into IF-boat?
Svar: 6
Visningar: 16318
Re: Does Honda BF 5 A4 LBU fit into IF-boat?
Although this engine fits into IF-boat mechanically, I can not recommend it. The new engine I have bought did not work. During several hours of trials, it started ones, but no more. They probably do not test them in the factory! It took a lot of my time until we were able (with the help of ...
av kubal
19 jun 2011 19:43
Kategori: Common
Svar: 11
Visningar: 23508
This is interesting solution. Thanks for the photos. I have just made the simplest topping lift: riveted an eye some 3 cm below the top of the mast at left side (close to the attachment of the back stay) with small roller. The line is fixed at the cleat at the left side of the mast, some 1 m above ...
av kubal
19 jun 2011 19:33
Kategori: Common
Tråd: What are the original jib sheet cleats?
Svar: 5
Visningar: 17501
Re: What are the original jib sheet cleats?
Thanks to both. I will mount the second kind of cleats (shown at the link from Johan). They are not so quick for operation, but universal and robust. And I have just bought discounted ones :-).
av kubal
05 jun 2011 14:26
Kategori: Common
Svar: 5
Visningar: 17501
Could somebody send me a photo of the original jib sheet cleats at IF-boat from 1976? What is the exact distance of the holes for screws? Is it possible to buy such cleats somewhere? I prefer to use the original holes covered under the unsuitable new cleats at my IF, not to drill new ones. Thank you ...
av kubal
03 maj 2011 14:06
Kategori: Common
Svar: 6
Visningar: 16318
The handle has to be positioned oblique down (in front direction). It is not necessary to remove it. But you have to put your hand very deep to reach it. The other possibility is to cut the handle. As I investigate it, it could be done. But in this case you have to cut the casted piece forming the ...
