Hmmm, den viktigaste delarna för helhetskonceptet som båten är?
Definitivt de Gardena o-ringarna vid rodret som måste bytas varje vår.
Annars, gängorna i bordsbenen?
Sökningen fann 6 träffar
- 18 mar 2014 15:33
- Kategori: Tursegling
- Tråd: Besticklådan, IF-ens viktigaste del
- Svar: 35
- Visningar: 82591
- 16 jan 2014 16:44
- Kategori: Beslag
- Tråd: Läckande fönster, med aluminium ram
- Svar: 18
- Visningar: 43628
Re: Läckande fönster, med aluminium ram
Om Lefant funkar inte kan du kanske försöka fixa det med en brytbladskniv & Sika 295.
http://www.ertec.dk/howtofix.htm
Fungerade jättebrå på min båt.
- 28 nov 2011 14:13
- Kategori: Annat
- Tråd: Lekkasje - demontere inredning/skap
- Svar: 3
- Visningar: 8717
Re: Lekkasje - demontere inredning/skap
OK, I see. Sorry about the suggestion for the fock track which now seems rather stupid.The chainplates are in front of 'skapet', though. They're in the cupboards, just to the right of the wall on the right hand side in your picture. The carpentry should be separate so you can leave the part in the ...
- 22 nov 2011 16:50
- Kategori: Annat
- Svar: 3
- Visningar: 8717
I've got the same problem with not having levelled the boat properly with puddles of water in the very same places - my commiserations. However, I have just installed new chainplates and can confirm that accessing them does not require dismantling any of the carpentry. From the inside, they're ...
- 07 okt 2011 16:52
- Kategori: Roder
- Tråd: '76 model roder & rorkult
- Svar: 3
- Visningar: 14059
Re: '76 model roder & rorkult
Tack så mycket, Johan. Taking a hammer and chisel to the rudder seems somewhat daunting but better than trying to undo the undo-able screws. Your images are much appreciated because I need to take out the lower pintle tap, too. Not because the tap is worn (I hope) but because I've discovered rot in ...
- 06 okt 2011 13:00
- Kategori: Roder
- Svar: 3
- Visningar: 14059
Hej, Jag har märkt vibrationer i min rodret och jag tycker det är dags att byta ut o-ringarna. Här på forumet Ardina skrev: 1. Ta bort rorkult 2. Vrid roderbladet 90 grader 3. Ta bort de 3 stoppen som hindrar rodrets tappar (på rodret) att lyftas ut från infästningarna/maljorna i (på båten). Stoppen ...
