Sökningen fann 9 träffar
- 15 aug 2014 10:34
- Kategori: Common
- Tråd: M26 Table Fittings
- Svar: 2
- Visningar: 7930
Re: M26 Table Fittings
Hi Yara, I have a pair of sockets, column legs and the table itself from my IF. They are little too big for IF. So I could give them away for almost nothing. But they are in Tallinn. Could be you will find them some place closer to you. If not, write me back.
- 15 aug 2014 09:25
- Kategori: Common
- Tråd: broken mast
- Svar: 12
- Visningar: 25910
Re: broken mast
Thank you, Maja, for the tip, I wrote Magnus a letter. Will keep fingers crossed. Ahoi,Yara, sorry for my English, it is as clumsy as my sailing. Stumbling all the time. I mean mast spar, of course ,the aluminium tube itself. They way I broke it ... standard situation, I guess. I was not sailing ...
- 13 aug 2014 21:20
- Kategori: Common
- Tråd: broken mast
- Svar: 12
- Visningar: 25910
Re: broken mast
Thank you, Maja, for a promt reply. The boat is insured, so I have some flexibility at my disposal when it comes to prices, I suppose. Yet if J2r4 mast is shorter, does not it mean that I have to change whole sail set for smaller ones, no? I was told these minutes now that my fellows sailors here in ...
- 13 aug 2014 19:52
- Kategori: Common
- Tråd: broken mast
- Svar: 12
- Visningar: 25910
Re: broken mast
Hi everybody, so it happened that I broke my mast bar today while racing under thunderstorm. I wonder what would be the chances to get another one second hand or buying brand new one, though the latter sounds unrealistic, given the dates of IF production. Any tips towards the solution are most ...
- 24 mar 2014 04:49
- Kategori: Common
- Tråd: Control lines - best way to lead aft?
- Svar: 15
- Visningar: 35566
Re: Control lines - best way to lead aft?
Ok, thank you Johan and Maja, all set now. Will do it as you suggested. May you have a good season, Johannes
- 23 mar 2014 06:16
- Kategori: Common
- Svar: 15
- Visningar: 35566
Thank you Maja, one more time. No existing outlets on this mast, just two massive knaaps on the sides to tie up spinnaker and groot halyards. I will follow your advise regarding the position of outlets. Yet, if I may still bother :P, one final question. I have testified to 2 kinds o outlets: simple ...
- 22 mar 2014 06:43
- Kategori: Common
- Svar: 15
- Visningar: 35566
One more time, is there a preferred/recommended distance from mast step where the wholes for halyard outlets should be drilled in the mast spar? How high from mast step, somewhere close to groot-boom fitting? The photo unfortunately does not reveal it. Going to drill it through this weekend. With ...
- 15 mar 2014 10:15
- Kategori: Common
- Svar: 15
- Visningar: 35566
Right, I apparently missed the "2 halyard outlets on both sides of mast bar"-part. Now it all makes sense. Thank you Maja, I was somehow counting in advance on your expertise. With warmest regards, Johannes
- 15 mar 2014 09:21
- Kategori: Common
- Svar: 15
- Visningar: 35566
Hi everybody, I am Johannes Saar. Bought IF two years ago from Mälar Lake in Sweden, sailed it to Tallinn and realised by now only that this is what I want too - control lines in the cockpit. Yet the photo and text posted in this thread were not enough to my modest mind to comprehend how EXACTLY it ...
