Sökningen fann 4 träffar
- 21 jun 2018 20:03
- Kategori: Common
- Tråd: Marieholm 261 rigging settings
- Svar: 6
- Visningar: 19122
Re: Marieholm 261 rigging settings
Maja, you think 380kg is about the right amount? 38 would be 780kg, that does seem very excessive.
- 21 jun 2018 19:58
- Kategori: Common
- Svar: 6
- Visningar: 19122
I wrote to Göran Helmer about this, and this is what he had to say: The way I put up the mast and rig is as follows. First I set the forestay so the mast is standing straight up and I tighten the forestay turnbuckle accordingly. The I take the upper shrouds. Measure them so they have the same lengt ...
- 21 jun 2018 16:15
- Kategori: Common
- Tråd: M26 with sailno. 501 - 505
- Svar: 5
- Visningar: 17665
Re: M26 with sailno. 501 - 505
I have sail number 527, hull number 521, according to the builder's plate. It is an M261, built in 1980. Did the production of the 2 boats overlap?
- 21 jun 2018 16:14
- Kategori: Common
- Svar: 6
- Visningar: 19122
Hello, I have a Marieholm 261, I think the only one in the US. I am getting new rigging made and need to know some settings. The rig on the 261 should be pretty close to a 26, so numbers for that boat will probably work. How much rake on the mast? How much tension on the cap shrouds? How much pre ...
