IF forestay and pin diameter
kjacobsen
Inlägg av kjacobsen »
I am planning to replace my forestay. Is the correct wire diameter 5mm or 6 mm. Is the correct clevis pin diameter 8mm or 10mm
Thank you
K. Jacobsen
The standard forestay diameter is 5 mm. This is also minimum as per class rules. It is not recommendet to have thinner forestay than 5 mm diameter.
