Outboards
david.lines
Outboards
I've not sailed an IF Boat before so this will be 1st season with Elpenor. The previous owner used an outboard on a bracket but I would prefer to use the lazerette. However size seems to restrict me to about 6hp - is this a big enough engine - I will be sailing in tidal waters.
David Lines
A 6 hp motor with a well tuned propeller will give you about 6 knots through water if there is no wind ahead. A more powerful engine will also give you 6 knots, as this is the maximum displacement speed for the IF-boat.
However, the stonger motor will also give you max speed if there is some wind. So for example, an 8 hp motor will give you about 6 knots, even if the wind is about 6-7 knots ahead.
If the tide current is near 6 knots or more, it will not be possible to override the current and make speed over ground, even with the strongest motor.
david.lines
Hi David,
I have a 6Hp Hi-Thrust Yamaha 4s/t outboard. Its a little heavy for my liking at 50kg but it will run my M26 into head wind and small sea's at 5-6 knots without working too hard.
On flat water, it will quietly move the boat at 6 knots on 1/4 throttle and use less than 1 litre of fuel / hour. Not bad!
Aparently the 'Hi-Thrust' 4 s/t outboards make a significant difference for heavier boats at slow speeds, such as displacement sailing boats.
Cheers
Matt
Cheers
Matt
david.lines
Outboards
Matt - thanks. looks like i will go for a Mariner with remote shift as this fits in the locker.
David Lines
