Outboard well
Captain_frog
Re: Outboard well
Inlägg av Captain_frog »
And here the last series
Water outlet.JPG (126.09 KiB) Visad 7457 gånger
Rubber lining.JPG (100.57 KiB) Visad 7457 gånger
Inside the well from above.jpg (94.77 KiB) Visad 7457 gånger
Inside the well door closed.jpg (97.37 KiB) Visad 7457 gånger
Skald
Re: Outboard well
Inlägg av Skald »
Thank you! Photos are very detailed and it looks like I can manage to do it myself :) Saved to favorites!
Crazy Mary IF2670
Re: Outboard well
Inlägg av Crazy Mary IF2670 »
Hi,
I am also suffering from the bracket at the back and I had 4hp Yamaha ( 5 knots) that cannot be tilt up, the prop was in the water while sailing ( cannot give up from my even 1/4 knots as I am going after/with 40 ft boats :shock: )... I am replacing her with 5hp Mercury Sailpower; it is charging (in max throttle), tiller arm is longer, tilts up, propellor is high pitch and one of the main reasons is the shifter arm is in the front... Mercury, Mariner, Tohatsu all the same engine made in Japan by Tohatsu; she will arrive next week.
I am really sick about the look of the outboard hanging at the back, I will check pod time electric motor to laminate on the rudder 8)
Thks,
