Outboard well
Captain_frog
Re: Outboard well
And here the last series
- Water outlet.JPG (126.09 KiB) Visad 8008 gånger
- Rubber lining.JPG (100.57 KiB) Visad 8008 gånger
- Inside the well from above.jpg (94.77 KiB) Visad 8008 gånger
- Inside the well door closed.jpg (97.37 KiB) Visad 8008 gånger
Re: Outboard well
Thank you! Photos are very detailed and it looks like I can manage to do it myself :) Saved to favorites!
Crazy Mary IF2670
Re: Outboard well
Hi,
I am also suffering from the bracket at the back and I had 4hp Yamaha ( 5 knots) that cannot be tilt up, the prop was in the water while sailing ( cannot give up from my even 1/4 knots as I am going after/with 40 ft boats
)... I am replacing her with 5hp Mercury Sailpower; it is charging (in max throttle), tiller arm is longer, tilts up, propellor is high pitch and one of the main reasons is the shifter arm is in the front... Mercury, Mariner, Tohatsu all the same engine made in Japan by Tohatsu; she will arrive next week.
I am really sick about the look of the outboard hanging at the back, I will check pod time electric motor to laminate on the rudder
Thks,
Thks,
